The problem started after a MAFT Pro and Q45 TB install. The car will start up fine but will not idle. The MAFT Pro was installed and set up according to the manual included and the TPS was wired according to the write up in the FAQ section.
The car seems like its "hunting" for the correct idle, like it does when the AFM is disconnected, and the AFR is all over the place. The MAFT Pro's set up:
Ver. 5.08
Config mode
Veh sel: 0
# of Cyl: 6
Displ: 3.0
Airfl mode: Speed den.
MAP source: GM 3bar
Load srce: use MAP
Baro mode: Read at key on
F out mode: Supra MK3
V out 1 mode: Set max
V out 2 mode: set max
AFR srce: Innovate LC1
F in mode: none
AUX 1 mode: aux trig off
FlowErr mode: SD/MAF
System Setup
SPK base: 0
Use VE table: 2
FE smooth: 30
AF TRdelay: 0
TM correct: 1.27
TM base: 0
F out max:0
Hi Ld pt: 143
Mi Ld pt: 100.1
Lo Ld pt: 36.4
Afterstart: 0
V out 2 max: 3.600
V out 1 max: 2.500
Main scale: +2.5
TPS Enrich: .50
TPS Decay: .80
TB size: 7
MAP enrich: .4
MAP Decay: .80
MAP TPS min: .500
MP is ~83 at key on, and bounces between 30 and 60 at the extreme rough idle.
My mods:
550cc injectors, FFIM w/ Q45 TB, Aeromotive AFPR @ 43PSI, Walbro 255
Here's a short video of the problem:
http://s246.photobucket.com/albums/gg97/TheCaptainWasHere/?action=view¤t=P7050054.flv
Thanks for any help guys.
Ver. 5.08
Config mode
Veh sel: 0
# of Cyl: 6
Displ: 3.0
MAP source: GM 3bar
Load srce: use MAP
F in mode: none
System Setup
SPK base: 0
Use VE table: 2
FE smooth: 30
AF TRdelay: 0
TM correct: 1.27
TM base: 0
F out max:0
Hi Ld pt: 143
Mi Ld pt: 100.1
Lo Ld pt: 36.4
Afterstart: 0
V out 2 max: 3.600
V out 1 max: 2.500
Main scale: +2.5
TPS Enrich: .50
TPS Decay: .80
TB size: 7
MAP enrich: .4
MAP Decay: .80
MAP TPS min: .500
My mods:
