GIT-R-DONE YALL HEAR
Well, this morning i started my car and it diedafter about 5 seconds, i restarted it couple of time and every time it did the same thing, also i would try to give it some gas, but it dies right away. I also noticed on my SAFCIII my high a low throtl setting is 0 all accross, yesterday it was fine and SAFC was not at 0.... my air/fuel ratio guage is in red wich means lean..... i also got a chek engine light checked the codes and got 14,31, 34... what do you think might be wrong.... i disconnected the air flow meter chleaned the connection, and the car will take gas now but its idling very ruough. pls help
nick
Addicted to oil
If your safc got reset, make sure the sensor type is set to "karmen". It will act exactly like you describe if its not. It will make it run super rich.
Dennis
Discussion Starter #6
Dennis
it is set as karmen but it is running too lean
ill check it today again and update you
thanks guys for your help
nick
