Car idles at 1500-1800 RPM after it has been warmed up. I only have a Blitz Nur Spec Exhaust system. Engine runs fine from point A to point B. However its sluggish when I give it mid throttle or full throttle because I lost to a G35 and a 350z on the highway. What should I look for?
1st 2jz 240 swap EVER
im guessin you have the TT correct? if so there is no reason you should be losin to 350z...especially on the highway, those things are slow as shit.
Check your plugs. Do you have a bad chamber somehwere? Engine compression check would might show you something. Perhaps a bad distributor.
NA-T T61
Reset your ECU and check for leaks. If this doen't solve the problem, find the articles to adjust the ideling on SF, and you can manually set it down. You should only be ideling around 750rpm.
