1 - 10 of 10 Posts
I would like to throw up my Ign timing map that was already in the Power-FC ECU (tuned by previous owners shop not in USA) for comments on how aggressive it is and or suitability for my cars setup/use. I do not know if that is OK to do, I will not name the Tuner. I just want comments on the Maps suitability for my setup. If some respected members/moderators say its OK to do so I'll post it up for comments. Thanks Phil.
chevyeater-on-sf said:
Why wouldn't it be ok?
I was not sure if it would be considered Intellectual property and upset any Tuners that might support the forum. Phil.
wastegate hose is pulled
Well Phil, IMO if you paid for a tune, then those numbers are your property. If the previous owner paid for it and sold it to you, that still makes it yours to me. That is how I see it anyhow.
-Brian
Ok, Here it is. I have had to make up a spread sheet and enter the amounts as I do not have the software to download the file. RPM across the Top and Load 1-20 at the side. Hope you can read the figures OK. The car ran great on the OEM ECU timing with 94oct + Meth inj at 22psi boost and I will be running 22-24 psi boost now, so I assume if this map is less aggressive than OEM I should be fine..... Fire away, Phil.
Load 1-20? Is this calculated load of some sort? Forgive me, I'm not familiar with the PowerFC system.
Yes, full noise uphill in 5th gear you would be in the 18-20 range of cells and cruising at 55mph on flat road you might be in 4-8 row some where. You can trace the map so after say a pull in 4th gear from just of idle to the rev-limit you can see exactly what cells were used so if you register engine knock it is easier to trace it what cells need adjusted. I thought a 20x20 Map like this was common to most stand alone ECU's and even the OEM one I thought has a 20x20 Map? Phil.
The AEM EMS (I'm very used to) uses actual load points instead of a calculated load cell. I think it makes things easier but, I'm biased. Anywho, assuming you've got full boost around 5k? it seems ok but may be a bit much if you make it to the top load row before then.
I guess nobody else was interested, eh?
Discussion Starter #9 (Edited)
Yeh. I was hoping for a bit more feedback/interest. What I can do with the Power-FC is make a temporary adjustment right across the Ign Map so I could pull 2-3 degrees to really make sure it's safe (moniter knock) and then adjust back up 1 degree at a time across the whole map until it is back to as shown. I think I get full boost under 5000rpm so I might pull the 4400+4800rpm cells in the higher load areas back to be safer for starters as well. Thanks for your input, Cheers Phil. PS In load range 12 @ 4400rpm setting of 33 degrees was a typo on my part it is 23 degress.
Discussion Starter #10 (Edited)
I now have the full software program that lets you go deeper into the Power-FC and make more adjustments than the Hand controller allows. This has bought to light the Apexi 1-20 load scale starts at 1=10kpa on up to 10=100kpa and so on until 20 =240kpa. The software lets you adjust this load scale, which I assume in my case of wanting to tune to about 30psi boost means I will want to adjust the scale evenly so it still starts at 1=10 but graduates up to 20=300kpa? I assume this is what you would do with likes of AEM and similar ECU's when setting it up to run max boost 30psi? (with 3 Bar map sensor as well) Thanks Phil.
1 - 10 of 10 Posts
