I just replaced my cam position sensor 7MGTE. Before installing, i lined up the drilled mark on the CPS with the little triangle grove on the splines, there's two rounded grooves on the CPS and ONE triangle groove so the triangular one is the one i matched the drilled mark to. Car started up fine and after letting it warm up and jumping Te1 and E1, The farthest it would let me set timing to was 5 degrees. NOTE: I was using the timing light that uses a number input so if i aim for 10 degrees on the gun, i have to adjust to zero on the pulley/ 0 on the gun, 10 on the puley so visa versa. What am i doing wrong ?? It's annoying cuz it won't let me receive full power.
