1 - 20 of 35 Posts
We attempted to install the Tanabe Downpipe again but could not get the stripted nut out near the 2nd cat. We tried to get a Dremel up there but there is no clearance for it. We tried almost everything and nothing work. Can anyone give me any advice before I take it to Motorsport Dynamics and have them take out the who manifold and charge me a arm and a leg?
BIG DICK BANDIT
Lock some vicegrips on it as hard as you can then tap the vices with a hammer. Works every time for me.
Lets go Nets
ooh i had the same problem, hacksaw, was my fix.
Brett
Brett-can you give me a detail advice on how you hacksawed it out?
I think it might be the same bolt that you had a problem with. The other 2 were easy for me but there was one that is supposely tighten with 50lbs of tq and that is the one with the totally stripted nut.
Supradoopa-what is a breaker bar?
A breaker bar is just an extension, or a socket wrench with a longer handle so you can get more leverage. If you don't have one, use a piece of pipe and slide it over the end of the wrench, and use it for extra leverage.
However, doing this could also break the bolt, so I would use this only if you can live without the bolts.
CraigK
Tom Henderson
a breaker bar is just a long kinda think bar with a thing for ur socket wrench..it helped me out a couple of times..haha..you can get one at any hardware store..or just get ur biggest wrench and get a pipe to fit over it for more leverage..
-Tommy
Discussion Starter · #16 ·
Ok I took it to Muffler Tec and they took a shot at it as well and nothing. Because it is the bolt that is up where they can't reach it they didn't know what to do either. I asked them if they can torch it out but they said it might be to dangerous. Here is everything we tried
Dremel- can't reach high enough
Smaller socket- just strip it even more
Torch- can blow things up not safe
Vice grip- no clearance for it
To the guy that melted it off isnt that dangerous?
And I refuse to take it to Motorsports Dynamic where they would charge me $75 and hour and it would take them 4-5 hours taking out the manifold, then taking it to a machine shop, then putting it back. Im not gonna pay $700 plus just to get my peace of shit downpipe on.
Im so despret for something that will work
Help Help Help Help
Discussion Starter · #20 ·
I had a hell of a time with mine. We got a torch and heated the piss out of it. You'll be safe dude, trust me. Also let the nuts sit in Fluid Film/WD-40/Liquid Wrench... anything for a few hours. We also used a stripped nut/bolt remover.
After all this we bought new studs from Toyota and replaced all three. Trust me you'll get it out, something is bound to work.
1 - 20 of 35 Posts
