gmacrae said:
Just wondering if you could answer a couple of questions i have. You're running 6spd on the aristo auto ecu right? Was there much involved in tricking the ecu to think its in park/neutral to let the car start? Did you do anything to stop the ecu throwing error codes? Does it feel like its pulling timing at certain points? Have you tried launching the car? - I've read that the auto ecu will cause the car to fall flat if you try this? though this was on a USDM auto ecu.
Im doing a manual conversion with an r154 in the next few months but haven't had any feedback about how the JDM auto ecu will respond -my car is JDM.
Thanks very much for any help you can give me.
I have not tuned my car with the aristo ECU. I've put 150 easy miles on it and aside from running a little rich at idle, it performs very well. Keep in mind I'm running low boost and going easy - breaking in the clutch and easing into it since I have no af/egt gauges. I have not launched it, but I have pushed it a little and I cannot detect anything with the timing.... it pulls very hard even running low boost.
I'm going AEM now, but the original plan was to run the aristo ECU with emanage ultimate. Now that I have had time with it, I think the emanage blue would work fine, at much less cost/work.
I'm running a 6 speed and the ecu doesn't care about the fact that it doesn't have an auto tranny hooked up. using the USDM ecu, we only had to splice one wire (the intake temp sensor on the JDM mani) and de-pin and re-pin the fusebox connector from the na harness to the TT harness (with one wire splice there). Everything fired up and works perfect so far, though I suspect I didn't turn my ac on yet (it's been 45 here!) and I think the compressor isn't coming on, but I will check that soon. I get no MIL light and have not pulled any codes for that reason.
I say run the aristo with an emanage blue or ultimate, now that I have AEM I'm going to be running it, but honestly, I could have saved $1200 and used my emanage ultimate, which I'm familiar with and have installed before.
-M
