1 - 4 of 4 Posts
i am in the work of mounting a alarm and gps in my toyota supra mkiv 2jzgte jdm/j-spec. i have the opportunity to connect up to 2 immobiliser on the car, on of them i have on the starter wire at the ignition switch , the other i have plan on mounting on the ecu somewhere..
someone that can come with some suggestions where to mout on the ecu?
Blue Thunder
I say the EFI main relay at the ECU. Labeled M-Rel. That should do it.
Blue Thunder
C'mon man. you been here long enough to know how to search !!! I'll help you this one time.... Go here find you car and look for the M-Rel pin. It controls basically EVEVRYTHING !!! wilbo666
1 - 4 of 4 Posts
