Theres a metal fuel line that passes through the 4th and 5th intake runner......how the hell do you remove this in order to get the head off???
LEADED FUEL ONLY
It is attached to a bolt on the intake manifold. Once you remove the upper intake manifold, you'll see it. Remove that, and then remove the banjo bolt on the motor mount and you shoudl be able to remove it.
Thanks a lot guys. Turns out a long extension above the manifold was all it took...don't know why I didnt think of it before. All help appreciated.
