Hey all,
I have a 1992 Mk3 that’s been imported from Japan with a 1jz and r154 combo.
Ive owned the car for over two years now and have not really had any problems with this car other than the twins going bad but no electrical issues at all.
Last night when I was about to leave work and drive home, I went to turn on the combination switch to get lights and I noticed I had no dash lights. Upon further looking, I noticed the taillights weren’t on either. However, the headlights did turn on but the motors did not push the lights up which is the first time that’s happened to me. I manually raised up the lights and tried to rotate the combination switch back to the off position and on again to see if the dash lights and taillights would light up. This time, the headlights didn’t turn on either.
So at this point, I have:
-no headlights
-no taillights
-no dash lights
-the headlight motors aren’t working.
what is working:
-turn signals are working fine
I have searched the Internet but have only found issues that are found after radio installs or only the taillights aren’t working or the dash lights aren’t working but none of them have the same matching symptoms that I have.
i did check all fuses, which came up good. I also have removed the lower dash and the steering wheel bezel and checked for any noticeable wiring issues which I do not see and also I made sure the combination switch was properly plugged in.
I would appreciate any advice that anyone has to offer. Thanks for your time.
-no headlights
-no taillights
-no dash lights
what is working:
- the door lights are lighting up
- the individual lights for oil pressure, battery and misc other small lights light up on the dash
