http://www.mirdrag.com/imstar/
July 26th at MIR
The rule book can be found on the website located above...for anyone interested i will post the class rules for which supras are suppose to compete in.
Who's gonna come though???
Wild Street
Entry Fee - $40
(10.99 and quicker cars only)
Race Format: Quick 16 field, Pro ladder, Heads-up, Pro tree, No breakout
Body: 1987 & newer vehicles only (VW models are permitted to run any year vehicle). Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. All windows must be functional. No body parts may be removed during competition.
Chassis: Full stock chassis is required. Cutting or drilling for lightening purposes of the chassis is not permitted.
Suspension: Stock type suspension cars only. Aftermarket direct replacement A-arms, struts, and shocks are allowed. Wheelie bars and ladder bars are prohibited.
Street Equipment: All windows must be OEM glass. Headlights and brake lights are required (one headlight may be removed for air induction). Stock dashboard and full interior from front seats forward is required (both front seats are required). Aftermarket interior and seats are permitted.
Exhaust: Muffler(s) are required unless vehicle is turbocharged.
Electronics: Two-steps, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Cars originally equipped with independent rear suspension must remain independent rear suspension (IRS conversions to straight rear axle are prohibited). Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Turbocharger: Turbochargers are measured at the inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing.
Nitrous Oxide: On cars that are not permitted to use nitrous oxide, all nitrous bottles and nitrous/fuel solenoids must be removed off car entirely.
Transmission: OEM transmission from the same manufacturer as car is required. RWD cars with manual transmission are permitted to use aftermarket stock-style clutch-assisted transmissions (no sequential transmissions).
Fuel: Gasoline only permitted. Aftermarket fuel cells are permitted.
Tires (FWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 26.0” x 10.5”.
Tires (RWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 28.0” x 11.5”.
Tires (AWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 26.0” x 10.5”.
2-rotor cars:
· Engine: OEM block from same manufacturer as car is required. Block may be swapped between different models of same manufacturer. Aftermarket blocks are prohibited.
· Induction: Engine must be EFI. Any style intake is permitted.
· Turbocharger (manual transmission): Limited to 80mm single or 60mm twins. Any type intercooler permitted. May combine with Nitrous.
· Turbocharger (auto transmission): Limited to a 76mm single or 58mm twins. Any type intercooler permitted. May combine with Nitrous.
· Minimum Weight: None
4-cylinder cars:
· Turbocharger (manual transmission): Limited to 72mm single. Any type intercooler permitted. May combine with Nitrous.
· Turbocharger (auto transmission): Limited to a 72mm single. Any type intercooler permitted. Turbocharger cannot be combined with nitrous unless vehicle is equipped with OEM automatic transmission for engine used.
6-cylinder cars:
· Turbocharger (manual transmission): Limited to 80mm single or 60mm twins. Air to air intercoolers only. May combine with Nitrous.
· Turbocharger (auto transmission): Limited to a 76mm single or 58mm twins. Air to air intercoolers only. May combine with Nitrous. (Nitrous prohibited on Domestic V6).
Street Fighter
Entry Fee - $40
(9.99 and quicker cars only)
Body: Any year import body. Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. No body parts may be removed during competition.
Chassis: Complete stock chassis and frame rails must be retained. Frames may be notched for clearance. Mini Tubs are permitted. 4-cylinder cars may be back halved.
Suspension: Stock style suspension cars only allowed. Four links and ladder bars are prohibited. Weld on sub-frame connectors and rear sway bars are permitted. 4-cylinder cars may have any type suspension. Wheelie bars are prohibited on all cars.
Street Equipment: Lexan windows are permitted. Interior is not required.
Exhaust: Muffler(s) required unless turbocharged.
Driveline: Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted. IRS cars may convert to straight axles only if it is a direct bolt in. Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Transmission: Any auto or manual transmission allowed.
Tires (FWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 28.0” x 10.5”.
Tires (RWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 30.0” x 11.5W”.
Tires (AWD cars): Any size DOT radial tire permitted. Maximum size DOT Bias Ply or Slick is 28.0” x 10.5”.
2-rotor cars:
· Turbocharger: Any size single or twin turbochargers are permitted. Any type intercooler permitted. May combine with Nitrous.
4-cylinder cars:
· Turbocharger: Any size single turbocharger permitted. Any type intercooler permitted. May combine with Nitrous.
6-cylinder cars:
· Minimum Weight: (FWD cars) None
· Minimum Weight: (RWD & AWD cars) 3200 lbs.
July 26th at MIR
Wild Street
Entry Fee - $40
2-rotor cars:
4-cylinder cars:
6-cylinder cars:
Street Fighter
Entry Fee - $40
2-rotor cars:
4-cylinder cars:
6-cylinder cars:
