shame that the search is still broken...
[1] RPS Max Clutch with Street Disc
[2] Powerhouse Racing Clutch Kit
My questions:
[1] Is the PHR stiffer than stock as well? how much in percentage?
[2] When i'm going to replace the clutch do i need anything else to buy, parts that will be worn out or better to replace them directly while the tranny is open?
I see at MVPmotorsports that there is list with all kind of items, but which ones are included with the clutches and which ones should i buy?
http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=780&SearchYN=N
[3] Wich one should i buy according to you guys? i'm not going to do any dragraces, just normal street use and some track days.
[4]What light flywheel do you recommend, the Fidanza or Unorthodox Racing Lightened Flywheel? or maybe a different one?
This package includes the RPS Max Pressure Plate and the RPS Street Disc. It is a full face organic disc that is extremely slippable and the most friendly disc you could ever put in your Supra.
This clutch kit can hold up to 440 foot pounds of torque & is 60% stiffer than stock. This clutch is the most streetable clutch you can buy and will hold 400+ RWHP.
The PHR high performance clutch was designed for the five speed manual transmission and can handle in excess of 600 horsepower. Perfect for any PHR Stage 1 or 2 equipped Non-Turbo Supra. Includes upgraded pressure plate and Kevlar / organic clutch disc for street use.
My questions:
