Does anyone know anything about this ecu.
It does not have the label that is on a regular 1jz ecu.
It has 2 label one have DENSO 9717570-915-0
the other have Denso 9717570-281-7 and RJ202201
sorry i wasnt specfic
I had a guy who does swap harness check my car because its not starting. He noticed that the ecu is different and said that it could be a modified ecu.
He has narrow down the starting problem to be the harness but could also be ignitor or ecu.
I want to know if this is a modified or stock ecu. Any info regarding why this ecu have a diferent label.
NO SOUP 4 U
From what little i found, an ECU with a denso sticker on is a refurbish ECU's by Toyota.
I see you found this archive post. I dont know what to tell you. There really isnt that much info on those numbers.
