1 - 7 of 7 Posts
A State of Trance
Quick question, is the wires to the resistorbox spliced in to the wires for the injectors? Hope you guys understand the question :)
Maybe someone has wiring diagram for the resistorbox?
Disect the harness and remove the stock injectors wires.
You`ll see the main 12 volt source... wire that to the single white/black stripe wire coming from the resistor (if you have six individual 12 ingition coming from each injector then soldier all six wires to the single white/black stripe wire).
The other six wires red/black stripe goes to the positive side of the injector (Note: all positive wire on the ignition should be uniform on all injectors.)
Good luck,
Andre
Low 9 sec SC300
cant you just add the ignition switched 12v source to the yellow/black or white/black wire and then cut the 12v non ecu side of the injector and add the 6 other red/balck resistor pack wires?
Low 9 sec SC300
he means so you have the path to the ecu there still and not on one or two
1 - 7 of 7 Posts
