Go to www.rceng.com they have formulas that will help. For the Supra use .55 for BSFC and don't exceed 85% duty cycle.
Later, Steve
Later, Steve
Increased duty cycle for your stock injectors, probably well over 90%, or higher static fuel pressure. If you haven't increased your static fuel pressure, then it's the increased injector duty cycle. It (higher duty cycle) can be done, but most recommend not exceeding 85% duty cycle for injector longevity and stable AFRs. Better, IMO, to have just a bit too much injector than smaller injectors with higher than recommended duty cycles on an ongoing basis.Supradedupra said:I just did some re-caculating....
my best dyno run bpu has been 432 rwhp... /.85 = 508 crank hp
plugging that into the forumla provided, I get that I need 575 cc injectors.... but the stock injectors are only 550 cc?.... what am I missing in the scheme of things?
Supradedupra said:thanks ken...
well, I think I am going with 720 cc denso injectors on an hks fuel rail for my setup.
according to my calculations, (and your .9 duty cycle)... I can produce 673 hp at the crank, which is right around where I think I want to be with my current transmission and clutch setup.
This is around the high 500's to the wheels which is still streetable.
I was told that my stock fuel pump is good for 500 rwhp, and that I should consider upgreading to a dual tt setup which should be good for 1000 hp or so (which is more than enough).
The reason I went with a t-88 is that it has possibilities for upgrades. I can gradually grow into the hp versus being capped at say 500 rwhp with a smaller turbo.
I can always upgrade to larger injectors at a later point![]()
holy mother of....Supradedupra said:I just did some re-caculating....
