1 - 3 of 3 Posts
I have a stock mkiii it is a non turbo model and I am wondering if I get a set of injectors off a mkiii turbo will it work and sence it is a turbo model it will dump more fuel in the motor I belive.... I really don't know just my intake and exhaust is giving it more air what should I do next???? Turbo injectors or fuel pressure regulator both or neither???
· tire killer
yes you can just drop the injectors in BUT, unless you love being pig rich at WOT dont do it. i have seen several ppl put the factory N/A's back in. i would just say leave it alone at intake and exhaust but thats just me.
-shane
p.s.
i went threw the make n/a fast stage. i now own 2 turbo cars and 1 near stock n/a.
if you want power get a turbo or go broke going for 250hp.
More fuel isn't going to help you out. If anything leaning things out a bit might prove beneficial.
I, as well as others in the N/A camp, would recommend you forus on weight reduction. Light weight flywheel, light weight rims, one piece drive shaft and so on.
How much of your exhaust has been replaced? Just a catback? Of have you got headers and a high flow cat as well?
1 - 3 of 3 Posts
