1 - 20 of 21 Posts
boost freak
aight...in my quest to 2 step w/the eman, i am trying to figure out just how the ign sys worx. the heck does IgF do?!?! appears to be a signal integrity check to me.....but i can't find a clear answer. if you know, post! ;)
boost freak
eh. kinda. i can't take all the credit- a dude on the eman yahoogroup thought it up....i'm just putting a new twist on it.
GOT BOOST?
If you interupt the IGF the ECU will loose RPM count and stop pulsing the injectors. =)
Also there has to be no signal for more than 8 sec or somthing like that. You have to cut the IGT signal .... That would interupt the ignitor imidiately.
boost freak
not really. all of the IgTs are pulses to each coil, you'll have a hard time interrupting all 3. the philip long 2 step messes with the IgF, so i'd imagine we can do the same....realize we're talking microsecond interruptions...enough to make it cut spark, then spark again. we'll see if it worx!
2/3 HP to the Paws
The best way to go about a 2-step would be to run the three injector wires through a black box and cut the rate.
This is kind of how the Racelogic traction control works on the MkIV, and it does a great job.
Pulling IGF = engine dies.
2/3 HP to the Paws
drjonez said:
then how does the philip long one work?!?!?!
No idea, I'm a road racer. :D
From a design perspective, though, it would be best to cut rate on the injector pulses themselves.
boost freak
Discussion Starter · #11 ·
hmmmmmmmmmmmmm. just thought about it more, i don't think you want to be cutting fuel....that can go sour real quick....kinda like how the rev limiter/FCO doesn't cut fuel, just spark....
2/3 HP to the Paws
Not if you do it properly, which is the key issue either way.
Don't cut the fuel, even if you didn't end up getting lean cycles, you want the extra fuel to be burning in the exhaust (assuming you are 2 steping for spool and not just a lower revlimit). You can cut spark after the igniter too, there is one wire for each coil and one wire common to all three. I have a diagram somehwere of how the igniter signals work if you really want to go that route.
GLEN
boost freak
Discussion Starter · #14 ·
the problem with cutting the signal after the ignitor is hoping that the field breaks down fast enough.....
does anyone know how to get in touch w/philip long?
wastegate hose is pulled
I think you would want to interrupt IGt input to the ignitor. I think you might still have a problem with the TCCS going into "failsafe" mode if it does not see enough returns on IGf from the ignitor. It wants to save your catalytic converter!
ps- got the I/C thanks doc. :)
GOT BOOST?
:rolleyes: :rolleyes: :rolleyes:
On the MK3 Turbo ignitor there is only one IGT signal wire. You have IGA and IGB which determine the coil sequencing.
Its called coil multy-plexing...
It works like this.
IGT is the timing advance and trigering even.
The IGA, IGB determines coil to be trigered.
IGA IGB
1 1 Coil one
1 0 Coil two
0 1 Coil three
It might not be the exact on off order but the principle is the same. More information is availiable at the Toyota study documents on line.
:eek: ;)
boost freak
Discussion Starter · #17 ·
ack. that's what i get for mixing my toyo ign sys info..... :p
oh well, i won't be testing for quite some time due to holiday events, etc....i'll prob try cutting IgT and IgF....
2J- is IgF the ignitor fire confirmation to the ECU on the MKIII?
GOT BOOST?
Yeah... It is emision safety... It tels the ECU that there was a spark and the ECU knows that the fuel was burned... If it doesnt see that signal it shuts the injectors off after so many consecutive missfires.
1 - 20 of 21 Posts
