Heres some pics of the inside of my ECU. There was some confusion as to wether this was a Gforce or not. Anyone familiar with the inside of one that has been chipped? Does the fact that the screw heads under the one side cover have been soldered over indicate that this is in fact a Gforce? How about the white label showing in the one pic between the two boards? Does the hand written sticker on top of a chip indicate non toyota work? Just trying to figure out if this particular ECU has been modified. The screw heads on only the one board are soldered. If you turn it over to the other side with the other cover off too those screw heads inside are not soldered.
