I really disagree, as do the folks that build the Tech edge WBO2, both the Bosch, and the NTK ARE pressure sensitive due to the fact that the sensors use diffusion(which is passive) in their operation. Forced induction can create a situation where expected diffusion is influenced by pressure waves from the turbo. In addition Bosch specifies a max temp of 1560 degrees for the L1H1. Even if you do not vbelieve this, why not simply utilise a bung 18" or so rear of the turbo just in case the manufacturer of the component is right
. In the RX7 community I have been told that when two sensors are placed one right behind the turbo, and one 18" downstream, that the difference can be as much as a full point. Further there has been discussion on this forum RE heat, and its ability to cause readings up to a point richer than actual. Here is an exerpt from the TE site;
"Wideband Sensor Positioning
The wideband sensor must be carefully placed in order to prevent damage to the sensor itself and to maximise accuracy. Also, if you use the sensor's output directly (via the simulated narrowband output) to drive your ECU then you should be doubly careful. Please follow all of these "rules" :
The sensor should always be placed on the engine side of a catalytic converter, unless you are testing the effectiveness of the convertor itself.
The gas temperature to the sensor should never exceed 850 degrees C (about 1560 degrees Fahrenheit).
The sensor should never be run without power to the WB unit (a hot sensor burns off carbon residues)
Always have the long axis of the sensor perpendicular to the gas flow (stops sensor clogging)
Position the sensor vertically or at most between 10 o'clock to the 2 o'clock position (this avoids cracking the internal ceramic structure should moisture condense internally)
We don't recommend using a short sections of exhaust pipe shoved up your tailpipe. A specially welded additional bung is the best mounting strategy.
The sensor reads the partial pressure of gases in the exhaust and infers the AFR, rather than by measuring some magical AFR directly. This may be an issue on forced induction, and in particular, on turbo-charged engines.
AFRs will indicate richer than they are, causing you to run leaner than you think.
Lean AFR's will be richer (or less lean) than indicted.
A solution is to ensure you locate your sensor away from the turbo, and certainly on the exhaust (low pressure) side of the turbo rather than the engine side. "
So, do what works for you, but for anyone asking the question, here are the facts as stated by folks whom most would consider experts. Regards, Carl Byck
