I am having some trouble figuring out the wiring for installing such an igniter. The wiring going from the ignition box to the coil pack is do-able with an ohm meter to figure everything out. But the four wires that go into the igniter (the 3 input signals and the voltage supply) are really tough to figure out.
So for whomever has installed a DIS-4, do you know the color combinations of the wires going into the ignition box (ond out too, so I can double check how it is hooked up). We should get this information posted on the forum so that it can benifit the supra community.
