1 - 7 of 7 Posts
1994 Toyota Supra Turbo 6spd
anyone know how hard it is to install the TRD tach? you'd have to calibrate it somehow right so the RPM's will match accordingly to the new tach #'s?
any install help/instruction would be greatly appreciated!
thanks~
It's an extremely easy install.
Once you get the gauge cluster out of the car, just unplug the old tach, plug in the new one and put everything back in place. No calibration or anything else. One word of caution though, don't pull the needle off the tach, because if you do, it will have to be recalibrated.
Check out this tech article for info on taking apart the dash.
http://mkiv.com/techarticles/Indiglo_gauge/index.html
Don't forget to disconnect your battery to avoid the airbag warning light coming on.
1 - 7 of 7 Posts
