The following is based on recommendations made by brake guru Mac Tilton. Mac is best known as the man that brought Carbon pads and rotors to racing. He is also the owner of Tilton Engineering; one of the main suppliers of brakes and clutches to Indy and F-1.
When bleeding brakes it is best to manually bleed them as pressure bleeders can cause cavitation and bubbles inside the system. Empty the brake reservoir with a turkey baster then fill the reservoir with a high quality brake fluid. Start bleeding at the furthest wheel away from the M/C and progress to the closest. So that would go RR, LR, RF, LF. Attach a length of clear Tigon tubing (available form any auto parts store) to the bleeder nipple, put the other end of the line into some sort of container so the other end will be submerged in brake fluid and open the nipple. Have someone in the car to pump the brakes. Slowly pump all of the old fluid out of the line until new clear fluid comes out, then have the person in the car hold the pedal down while you close the bleeder. Have the person lift the pedal up slowly and then push down slowly while you open the nipple. You have to communicate with the pumper because the bleeder should only be open on the down stroke of the brake pedal. It is important to pump slowly to avoid bubble-forming cavitation. Continue to pump until you cannot observe any bubbles in the clear Tigon tube.
Get a rubber mallet and tap the caliper to dislodge any bubbles that may be stuck inside the caliper and bleed some more until no more bubbles come out. Do this at all the wheels and you are done. Be careful not to let the reservoir run dry or you will have to start all over. On ABS equipped cars you want to be extra careful about this because it takes forever and a lot of fluid to bleed a completely dry ABS system.
I found this info on the web...hope it helps.
Jeff
