1 - 4 of 4 Posts
Well I decided to get ride of the stock piece of plastic that draws air under the pass. headlight in order to get a better flow of air.
As you can see
I already have ran the ducting down under the headlight and I had to cut a little bit of plastic that was in the way but My question is, what would you guys use for a scoop in the grill???
Ive thought about making my own from aluminum or going out to look for a plastic piece of some sort that would work.
Any suggestions is appreciated.
do you want to be able to see the aluminum?
I would check out some brake duct scoops as posted above; but just to get an idea you could go look around in the air conditioning section of home depot. I know they have aluminim ducts, but dont know how small they go.
1 - 4 of 4 Posts
