1 - 7 of 7 Posts
What are the sizes of clamps that we need for our intercoolers? I am trying to order the NAPA T-clamps and I cannot find the sizes.
Thanks,
Adam
Supra OG
For the IC hoses, you will need NAPA part# 7051532, which is a 2.75 min t-bolt clamp. If you want to do all your hosing from the turbo outlet on over to the throttle body, you will need a total of 9 clamps of that size and 1 clamp of a 3.25 min size for the throttle body (can't remember the NAPA #). I suggest you also pressure test your system or else plan to tighten the t-bolt clamps down more than you would normally think (they are wider than stock so take more clamping force to completely seal).
Thanks for the information Jim. I appreciate it.
Adam
Formerly from Portland now living in Houston
Old School
From Mohd:
705-1532 --> for all the fittings,,,need 6 or more depending on your setup
Retail: 3.73 with discount 2.32
705-1533 ---> for the TB to ic pipe fitting,,,need 2
Retail: 4.09 with discount 2.78
For a discount ask them to enter code [06004]
AAA DISCOUNT CARD PROGRAM
We has your money!
asdf
I have a spearco front mount with all hard pipes..I am going to order new silicone connectors for my piping...it looks to me like all the piping is 3 inch except for the piping to the throttle body..does this sound right?
Supra OG
For the stock IC setup, it is 9 of the 1532s and 1 of the 1533s.
Lagtime said:
From Mohd:
1 - 7 of 7 Posts
