Is this for the MKIV Supra TT or NA?
Thanks,
Dusty
Thanks,
Dusty
also when do you expect the carbon fiber cooling plates? Thanks
Hi, I just installed a spearco ic kit & it came with steel pipes:barf: it was powdercoated on the outside but not on the inside & had rust!!so I would like to replace them with aluminum i'm going with a phr turbo kit so that takes care of the inlet side but leaves me with nothing for the outlet also the bov is on the inlet side will the phr pipe have a flange or does it need to go on the outlet side of the ic Thank you
