hey there nice supra very clean...
Vehicle Speed Sensor - No "SPD" signal to ECU for 8 seconds when engine speed is between 2,500 RPM and 4,500 rpm (7M-GE) or 4,000 rpm (7M-GTE) and coolant temp is below 80 deg. C (176 deg. F) and neutral start switch is off. Trouble areas - Vehicle Speed Sensor Circuit, Vehicle Speed Sensor, ECU.
check the sensor out and clear the codes.
and the 43 is the starter signal, check your ignition system and starter.
if both are fine i would look into your ecu
