1 - 20 of 48 Posts
At the 1/8th mile last night and launched off the 2-step (11psi) 5000 RPM and bam went my diff. It broke the case and everything. I was running the ET streets with Tien HA's set to soft. I have a ITS 66DBB turbo with EMS.
My first love is road racing but my buds all go drag racing so I went and learned the hard way. Is the TRD setup worth the money?
If anyone has or knows of someone that has a J-spec or US spec complete six speed rear end (pumpkin, hog's head) case and diff let me know please.
www.ziptieracing.com
yeah. not sure I would go through the effort again if I had a functioning factory diff. But since you don't I'd no question buy the clutch pack from TRD.
IG UPDATES @ #BADMTHRFUKR
sorry to hear about the rearend. I havent taken my car to the drag yet but I'm very nervous since i read about so many people breaking these or the drive shafts. If something does happen to mine then I'll definately buy the Trd unit since i hear good things about them. Good luck on the rearend.
1994 Toyota Supra Turbo 6spd
supranatural,
sorry to hear about your rear end. mine just blew up 2 weeks ago at the drag strip as well! pretty shitty.....
anyway, you have to check if your ring and pinion gears are still okay. i'm not sure what's all gone on mine but you might have to get a set and they have a 3.27 R/P set for the 6spd you can swap with the TRD diff. that is another $450 though.
good luck and keep us posted what you do. i'm thinking about going TRD with the 3.27 or just going straight auto rear end (3.77) i have a 6spd
sleeknsilver said:
supranatural,
I'm trying to decide what to do. I'm pretty sure my case is cracked so the least expensive way to go would be to buy a complete used unit and be happy. I really would like to get the TRD diff with 3.27 gears but money is tight right now.
3.77 would make 2nd useless I would think. Not to mention you would have to shift to 5th in the 1/4.
this is true for MOST supras... BUT according to the calculator off of mkiv.com a 28" tall tires and with a V161 tranny, you can be trapping 146-150 MPH in the 1/4 (4th gear) with a redline of 8000-8200 RPM ;)
i believe a complete new rear end would be over $2000! TRD lsd, 3.27 gears, rebuild parts would run you $1500 (plus labor)
Discussion Starter · #11 ·
Yeah but my case is cracked so I need to buy that first than buy the LSD for $800 the 3.27 gears $425. If I can just buy a case in good condition I'd probably go that way.
SupraNatural,
I just recently purchased a Kaaz lsd off ebay for $807 shipped from drift factory and had Paul Efantis @ MSP install it and he said that this is far the tightest Lsd he's installed and the only thing thats come close to it is the Cusco that he has in his person car, and the Kaaz is adjustable since its a clutch type lsd.
I can send you a link to the purchase if need be.
Just thought i'd let you know my experience!
vnt :)
Discussion Starter · #13 ·
vntperformance said:
SupraNatural,
vnt :)
Yeah PM me the info. I'd like to keep it off the boards out of respect for Dusty (MVP). One thing with ajustible items, how do you know what to ajust it to?
Does anyone else have any experience with the Kaaz unit?
I have mine adjusted to 100%, but it all depends on what type of driving you do. YGPM!
vnt
SupraNatural said:
Cool, so the TRD unit is a 1.5 correct? Does Greg have the 3.27 gears do ya know?
Thanks for your input, it really does mean something coming from you.
Chris
Yes, the TRD is a 1.5!
vnt :)
1 - 20 of 48 Posts
