thanx for the input guys. I'm just looking at the repair manual on injector removal, seems pretty straight forward, I should just take my time and make sure everything is put back the right way.
is there anything I should be careful about?
also, should I replace all the gaskets and seals noted in the repair manual (ex, throttle body, inktae manifold, EGR, fuel rail gaskets etc?) other than the injectors insulators and seals?
last, I dont think I would need to disconnect all the sensors and solenoids ON the intake manifold correct? just need to unplug them?
thanx for your helps, it would really help me get thru this with a bit more confidence.
Jonas
