Just got new wheels for the car and the front wheels just BARELY cleared the caliper so i used 5 big washers inbetween the wheel and the brake rotor as a spacer...is this safe? lmk thanks
Mike
Mike
I used the same guys for my wheel spacers. There are a couple shops in California that can make you whatever you want. They use quality 6061 aluminum too.pwpanas said:
uhhh. help me out here. Please explain how changing the offset of a wheel effects the alignment? It isn't mathmatically possible.Hewey56 said:Another problem, putting a spacer will also through off the alignment, but again this shouldn't be enough of a change(depending on the thickness of the spacer) to cause any problems.
What do you know about math? You went to the wrong college to be discussing mathematics.... ballet or poetry however... you are more than qualified - twinkle-toes.turbomx5 said:uhhh. help me out here. Please explain how changing the offset of a wheel effects the alignment? It isn't mathmatically possible.
Pushing the wheel farther out on the studs will cause the weight to be distributed differently, causing the suspension to compress a little more, and change the camber.turbomx5 said:uhhh. help me out here. Please explain how changing the offset of a wheel effects the alignment? It isn't mathmatically possible.
hahaha. dude - you're an asshole.Jim Swantko said:What do you know about math? You went to the wrong college to be discussing mathematics.... ballet or poetry however... you are more than qualified - twinkle-toes.
We're 7-2 while the fairys are 8-2... so don't even start talking that smack. :fruit:turbomx5 said:hahaha. dude - you're an asshole.
how's your basketball season going?
