1 - 8 of 8 Posts
is it safe to clean the alternator with degreaser and water, or is there another way to clean it with out messing it up.
do you mean like hardcore spraying it with the hose? i wouldn't try it... damp cloth with degreaser on it should work fine as long as its not soaking wet.
they make electric parts cleaner. its at atuozone/advance/pepboys. usually found by the brake parts cleaner. it works great!
I detail cars all the time i always use purple power cleaner to degrease the engines then i power wash them off then blow dry with air then hoze armor all on everything then i blow dry again then wipe off the excess. I never had a altornator go bad yet !!!
beautiful machines
the worse that can happen it the bearings will make noise there only like $30 new and a sinch to replace you might as well do the brushes too for a nother $15
1 - 8 of 8 Posts
