I am turboing my N/A and will probably be in the 400 range when I am done. Maybe more once I run up the boost.
I ordered a 255ltr/hr Walbro pump (not the high pressure pump). I plan on putting a double banjo fitting at the fuel rail to supply the takeoff for 2 additional 720cc injectors controlled by an AIC, plus the 6 stock 330cc injectors.
My question is, will the combo of -6 stock line and the hard tubing that makes up my stock fuel delivery line be enough, or should I plan on running a braided -8 line?
I would think the stock delivery would suffice, but lemme know if you know otherwise...
