1 - 20 of 26 Posts
I just recently purchased a 94 Supra Turbo and was wondering if the gas light is suppose to turn on at a quarter tank. I had a Lexus SC300 and the gas light would not come on until i hit Empty. Is the Supra's gas tank 20 gallons? or 16 gallons? The needle was at 1/4 tank and the gas light came on so im guessing the gas tank should be 20 gallons. I just want to make sure that when the gas light is on that im not running on fumes.
Last stock TT on Earth
My gauge sucks. Several times it has "stuck" anywhere from full to 1/2 full until the light comes on simultaneously as the needle becomes "unstuck". I think it's a soilder joint issue or somthing since I can cause the gauge to fall (when it's stuck) when I push against the dash but I'm too busy to dick around with it.
I take it no one has let the needle go below E.
No one does intentionally because letting the tank get low causes nothing but problems such as the fuel pump overheating and sucking up crap that is sitting at the bottom of the tank, not to mention walking to the nearest gas station after your car dies.
Having said that, I have done it due to the problems I described above, and yes I have seen the needle drop below the E-dash. It was in 5pm traffic on the outerbelt during a rain storm and needless to say I was not happy about it...
« f ï z z | ë »
i notice that my light will go on very early while if i'm driving on a long road trip. if i do mostly city driving then it will turn on closer to the "e."
i believe the supra gas tank is 18.5 gallons.
I have let the needle go below E not by choice but because I was in the middle of nowhere. Turns out when I get to the gas station I still had 8 litres left! I put in 62 litres and the manual says it's a 70 litre tank. The needle was a good ways below empty too. I noticed that when my light comes on at 1/8th tank and I fill it up I still have 15 or so litres left in the tank which is quite a bit. Even 8 litres is a lot to have when your below E.
My needle doesn't seem screwed, it always behaves the same by the way.
Newbie
What exactly make the light turn on?
Like what makes the light turn on? Does it turn on when the fuel guage needle gets low? Or does it turn on when the "bougie" (sp?) in the fuel tank feels that the tank is low? (if you ever changed your fuel pump, you'll know what I'm referring to).
Cause my light has never turned on and I was just wondering if it even works.
isn't it better to get the most out of your gas by driving around a couple miles on E...i mean the way the gas tank is made is retarded...when you hit empty theres still a lot of gas left for you to drive around a bit
Newbie
Huh? How do you get the most out of your gas that way? Whether your tank has 1/4 or 3/4 full has no play in mpg. :dunno:
1 - 20 of 26 Posts
