Is the traction control is worth it, just to get the AEM EMS?
I'm on the fence now,
cause been having major igintion problems
see thread
http://www.supraforums.com/forum/showthread.php?t=371693
at this point I was considering the AEM, just so I can ditch the ENTIRE stock ignition system and run with the 97+ ignitor and coil packs.
but some people suggested I work fix the stock system first,
at this point it's not fixable as I've tried justy about everything
only thing left is to bypass the stock wiring and run new wire for the whole ignition system; figured since I'm already doing that might as well convert to coil packs.
But aside from this issue, my (NA-T) hp doesn't really justify.
I have 440 injectors, V8 maf, wlabro, etc.. the turbo is on the small side TE04..
so I'm figureing best possible potential is around 400rwhp
and piggy backs are sufficent for that level of power.
Only other benifiet deciding if I should get the AEM now is getting the added bounus of traction control, as most of our NA/NA-T cars lack traction and LSD.
smaller benifit would be realeasing the BOV external, since the AEM uses a MAP sensor
keep in mind, I can offset my cost of the whole system by selling off my AFC2, V8 MAF, stock ecu, coil, distributor, AVCR (already taken out) MSD 6BTM (already out), etc...
also rewiring the system for coil packs would be easy then rewiring the existign system, and the coil pack direction have already been documented by WhiteBlaze and Neostreamsupra. If I rewire the stock system I'll have to figure out were all 5 wires to and from the ignitor route too; so there will be research time involved.
what are your thoughts?
thanks
see thread
thanks
