Just need to know if the turbo houseing is cast, and i need to know where to get a flange to weild to it. I need a 90 degree elbo 2 inch so i will be able to hook up my ic pipeing.....Can you even weild cast?
The compressor housing is cast aluminum and can be welded. Don't you see all the other Supra's doing it?Just need to know if the turbo houseing is cast, and i need to know where to get a flange to weild to it. I need a 90 degree elbo 2 inch so i will be able to hook up my ic pipeing.....Can you even weild cast?
I see some pop up every once in a while on ebay. Also, check out precision turbo's website I think I've seen some there. Might want to also try some SF vendors.yeah i seen thea but i dont know where to get the elbow
