The engine can handle the extra revs (at 7,500), but I have heard of the front seal going out under the additional pressure. Your car should not rev to 7,900rpm. Even with an ECU upgrade, it should hit a fuel cut by 7,800rpm. Does or did your car ever have white faced gauges? Are you sure it is giving you an accurate reading?
Later, Steve
