1 - 10 of 10 Posts
spracingonline.com
im in the middle of pulling the engine on my 94 tt 6spd and the engine is separated from the trans about a 1/2 inch and it wont come all the way out. is there a clip or retainer inside the trans that needs to be released that im not seeing.
Mind if I do a J?
Edit: Didn't read it was a 6spd. Good luck.
1,2,3 Pulllll!!!!!!!! 1,2,3 Pullllllllllll
spracingonline.com
Discussion Starter #9
I had to remove the throwout bearing fork, then it came right out. Also my car has the RPS twin disc, is the factory throwout bearing attached to the pressure plate like this one is?
1 - 10 of 10 Posts
