-Single turbo supra
Is my manifold supposed to have something plugging these two holes or something connected to them?
I've seen pictures of others single supras and something is usually connected to them
Medium Ballin'
At one point there was a vacuum line that ran from that nipple (left "hole") into a hard line that bolted to the second "hole". This line then ran to one fo the hard lines across the firewall and over to the hard vacuum lines that usually run over the stock twins if I remember correctly.
So, no, it doesn't have to be used. Just make sure you don't have any vacuum leaks anywhere.
Supra Owner Since 1996
They are just bolt holes that hold the line that runs from your TB to your charcoal canistor I do believe. Do you still have your canistor?
