Hello guys!
So i recently got my head for my 2jz-gte back from the machine shop after being resurfaced. I just wanted to make sure the finish on the surface was ok because if you run your fingernail over the surface, you can very faintly feel the ridges the cutting machine left on the surface. If you run your nail over the surface real fast you can hear a soft "zipping" noise from your nail moving across the ridges. It's very hard to see, and the surface looks polished, but if you get the lighting just right you can see the small lines in the surface. Is this ok to put back together?
Thanks fellas!
Thanks fellas!
