Hi Guys,
I need a quote for the following items. The car is a JDM 93.5 MKIV 6 speed (right hand drive)
I'm basically refreshing everything / rebuilding everything. I'm not looking forward to the price of all this.
Can you include shipping to Perth 6061, Australia
V160 Oil - Enough for 2 changes
8 flywheel bolts for a JZA80 6 speed
Rear Main Seal
Front Main Seal
input shaft seal
tail shaft seal
shift shaft seal
Rocker Cover Gaskets/Seals (2 needed?)
Late Model Clear Indicators
Wiring Harness for the coil packs - The internals of my current one have died from age and heat
The side clips that hold the front bar onto the body(they site up the very top corner of each side holding the bar onto the body)
Leather Shift Boot
Thermostat
All the seals/gaskets needed for disassembling the upper and lower intake manifold
4 x EFI relays - Are these generic? i.e could I get them locally from anywhere
No.2 Oil Pan Gasket
Water Pump seals
The 2 O-rings for the NO.1 water bypass pipe
Front Bumper Toyota emblem - What colors?
TRD Engine Mounts
Rear Rubber Mounts for the hatch - the "hatch rattle fix"
And thats it.. If you can give me a price for each componant and availability
If you can email me - [email protected] it would be appreciated
08885-01306 LIST 49.41 COST 36.54 EA X 3
90910-02115 LIST 10.12 COST 7.48 EA X 8
Rear Main Seal
90311-90006 LIST 36.87 COST 27.26
Front Main Seal
90311-46001 LIST 12.86 COST 9.51
input shaft seal
90080-31031 LIST 13.39 COST 9.90
tail shaft seal
90080-31029 LIST 22.53 COST 16.65
shift shaft seal
90080-31032 LIST 6.98 COST 5.17
11213-46020 LIST 13.53 COST 10.00
11214-46011 LIST 13.53 COST 10.00
90210-07001 LIST 2.03 COST 1.50 EA X 16
81510-80086 LIST 72.26 COST 53.43
81520-80086 LIST 72.26 COST 53.43
81515-14390 LIST 23.44 COST 17.33
90980-11246 CONNECTOR LIST 5.75 COST 4.24 EA X 6
82998-12440 TERMINAL LIST 5.20 COST 3.85 EA X 12
52536-14030 RETAINER LH LIST 18.38 COST 13.59
52535-14070 RETAINER,RH LIST 18.38 COST 13.59
Leather Shift Boot
CANNOT SUPPLY IN RHD
Thermostat
90916-03093 LIST 16.58 COST 12.26
16325-62010 LIST 4.89 COST 3.62
17177-46031 LIST 13.25 COST 9.80
17176-46030 LIST 9.45 COST 6.99
22271-46030 LIST 6.63 COST 4.91
90987-02009 LIST 33.10 COST 24.48 EA
No.2 Oil Pan Gasket
00295-00103 LIST 12.75 COST 9.36 EA X 2
Water Pump seals
96761-24040 LIST 2.57 COST 1.91
16325-46010 LIST 3.17 COST 2.35
96761-24023 LIST 2.57 COST 1.91 EA X 2
16343-46030 LIST 3.34 COST 2.47
75314-14010 LIST 20.95 COST 15.49 [GRAY]
TRD Engine Mounts
12360-JA800 LIST 129.00 COST 113.00 EA X 2 OUT OF STOCK
OEM Engine Mounts
12360-46070 LIST 158.62 COST 117.29 EAx 2
67293-14051 LIST 5.20 COST 3.85 ea x 2
90159-50116 LIST .63 COST .47 EA X 4
SHIPPING 100.00-140.00 RANGE USPS GLOBAL EXPRESS MAIL
Ok cool.
I'd like to order the following parts
08885-01306 LIST 49.41 COST 36.54 EA X 4 146.16
90910-02115 LIST 10.12 COST 7.48 EA X 8 59.84
90311-90006 LIST 36.87 COST 27.26 27.26
90311-46001 LIST 12.86 COST 9.51 9.51
90080-31031 LIST 13.39 COST 9.90 9.9
90080-31029 LIST 22.53 COST 16.65 16.65
90080-31032 LIST 6.98 COST 5.17 5.17
11213-46020 LIST 13.53 COST 10.00 10
11214-46011 LIST 13.53 COST 10.00 10
90210-07001 LIST 2.03 COST 1.50 EA X 16 24
90916-03093 LIST 16.58 COST 12.26 12.26
16325-62010 LIST 4.89 COST 3.62 3.62
17177-46031 LIST 13.25 COST 9.80 9.8
17176-46030 LIST 9.45 COST 6.99 6.99
22271-46030 LIST 6.63 COST 4.91 4.91
96761-24040 LIST 2.57 COST 1.91 1.91
16325-46010 LIST 3.17 COST 2.35 2.35
67293-14051 LIST 5.20 COST 3.85 ea x 2 7.7
90159-50116 LIST .63 COST .47 EA X 4 1.88
Sub Total 369.91
Shipping 100
Total 469.91USD
Can you confirm this is correct?
Also. What are the payment options? Do you accept paypal? Thats about the only thing I can pay with as I've cancelled my cards of recent
Also are the TRD Engine mounts likely to be back in stock any time soon?
Hi Curt,
I need the following asap.. I'll wait on the rest till the trd mounts are in
08885-01306 LIST 49.41 COST 36.54 EA X 2
Rear Main Seal
input shaft seal
tail shaft seal
shift shaft seal
+ shipping?
Can you give me a total and a way to give you a credit card etc?
Also an estimated delivery time?
630.279.2265 parts direct
630.835.0122 parts fax
[email protected]
My weekly hours are 4:30am-4:30pm M-F
You can call me or use e-mail. If you use e-mail I need your name,address,phone number and CCinfo and items requested.
shipping fee 65.00 , this would ship out on 6/3 arrive to you by 6/9
