I'm officially known as 1jzsupraguy now. before i was just posing as a 1jz owner but as of today the 1jz has started successfully. the only two problems i have is the hose on the firewall and the ps rack leaking...
i connected my hoses exactly like the picture above and now there's smoke coming out of the hose with the red circle... maybe i just didn't tighten it good enough.
however, on the 1jz the red hose actually goes to the blue circle and the blue circle goes to the red circle... it can be reversed right?
and then my other problem, which i know what wrong with it already is that, when i tighted the union bolt on the steering rack, i accidentally went in at an angle and not the threads are messed up. i got the bolt in correct at the moment but i will no longer tighten all the way so it leaks a little down there.
other than those two problems, seems like i'm all set.
still need a transmission crossmember before i can drive it so if anyone could get me on asap, that would be great!
