1 - 13 of 13 Posts
Tried searching to no avail. When you remove the J-Tube do you just connect the two fuel lines back together?
Any negative side effects to consider?
M
thought you would want to remove it if you bought a bigger fuel pump?
you would be amazed at the size of the restriction it is.i just pulled mine the other night and i don't think i could fit a needle through that thing.
I heart 80's Toyota's
i don't think the j tube will affect stock fuel pressure... its a failsafe incase the factory reg shits out
Discussion Starter · #10 ·
Yeah - I was very surprised to see the restriction was maybe a 1/16th" hole.
If the J-tube is removed will the stock regulator still hold the pressure where it should be?
Another sputid question :doh: . . . Why is there a hole in the block behind the J-tube? Does it have some function?
Just some guy
Thats where the mechanical fuel pump bolts to on the old M series motors. The oil pump driveshaft had a lobe to drive the pump. In fact, the 5mge driveshaft still has the lobe on it. The 7m finally got rid of it.
1 - 13 of 13 Posts
