1 - 14 of 14 Posts
grease monkey
So im pickin up a used 7mgte engine from japan to drop into my 87 cuz i blew my crank so im curious if its gonna drop in or if there is any mods needed to be done. any advice would be appreciated tia
Cameron
25psi Bliss
It's almost an absolute that you consider cracking open that block to perform some rudimentary refreshing of the block; bearing gap / tolerance inspection, replacement of all coolant, PCV, and vacuum hoses, new head bolts, and definitely the HG.
Please note, the last time anything 7MGTE was in a JDM chassy was ~'90-91. So, either that motor was sitting around for 16+yrs, or this establishment sold you some "JDM" jive. If I had to wager, I'll bet you've got a "very" used USDM motor....
Heavy Right Foot
you'll know pretty much right away if it's actuall a jdm motor.. by the above mentioned and the throttle cable linkage is different..
i switched the entire intake manifold when my newish motor came in, throttle body is a little different..
plus the comfort of new seals and gaskets is comforting..
function > form
You blew the crank??? As in scored journals from oil starvation or actually breaking it? If so, how did that happen?
grease monkey
haha jus scored the journals down 2thou " so and as far as gaskets go, parts are here new hg and full gasket set, im gonna rebuild the whole engine and could some one breif me on if i shuld throw my old egr bak on or is it good without?
Formerly Nosechunks
Cut crank and rebuild origional motor, case closed.
Its simple and cheaper, just get a gasket set, main and rod bearings, and the crank cut and call it a day.
i swear this thread was gonna be about a jap engine in a ford or chevy or something .btw it should be a simple procedure considering its from the same car
grease monkey
Discussion Starter #14
1 - 14 of 14 Posts
