1 - 3 of 3 Posts
Hello,
I am finally swapping my twins for single turbo on my 94 JDM Supra 2jzgte. I want to get this done properly the first time. I would like to know what exactly people are doing with the oem unused wires (ie vsv ones), coolant pipes? Are there any detailed turbo swap posts?
Thank you
It’s the same as for LHD. You do not NEED a GE water pipe.
The only difference is the heater core hoses which you can leave as-is, the LHD tutorials that have part numbers for new heater core hoses likely won’t fit a RHD.
1999 Toyota Altezza
Hello,
Thank you
There is a detailed 2JZ IS300 GTE Swap manual that has a lot of good detail.
See link below. You can find good info on page 39 onwards on single turbo setup.
253717
1 - 3 of 3 Posts
