1 - 10 of 10 Posts
Only Time Will Tell
ok i just got a 2jzgte but idk if its a jdm or us spec, wat r somethings i should look for to give away wat 2jzgte i have, i know the obvious like oil pan, injectors, MAF, but is there anything else i should b lookin for to help figure out which one i have...
adammackintosh.net
pretty safe to assume its jdm until you prove otherwise.
but you can find out in 3 seconds if its running MAF or MAP.
if the air intake pipe has no MAF sensor on it, then you have a jdm motor; and the MAP sensor is over on your intake manifold.
adammackintosh.net
ct20a are jdm turbos
usdm is ct12b
1 - 10 of 10 Posts
