1 - 16 of 16 Posts
feeding your habit
Hi Curt,
on my JDM motor, there is a hose that runs between the intake mani and the valve cover with a little check valve. It is just forward of the IAC and in the valve cover is a little check valve. Is this present on USDM motors?
Do you have the PN for the hose?
Thanks,
Mark
feeding your habit
no, the PCV valve, I believe is on the other cover, the exhaust side cover. This is on the intake side cover. It runs between the intake side valve cover and the intake plenum.. hose is and "s" bend and about 4" long.
-M
feeding your habit
I do not. Can you post the fiche for the intake side valve cover, then I can see if it has the port I have on my motor.
-M
feeding your habit
***I need part 12261...... Part and price plase on that hose.....
***Can you post a fiche showing the short hoses that go from the heater core (from firewall to motor) please?
***Price & PN on stem seals please.
*** price and PNs for (looking at FSM clutch unit, GTE, 6 speed, clutch assy) all the parts stuck to the clutch release hub, less the TOB.
As always thanks for your help,
Mark
feeding your habit
Discussion Starter #8 (Edited)
Curt, I got a used set of aluminum motor mounts (bolt to the block) and they are from a 97 TT.
I also got a used set of TT isolators, but they must be from a 95 or older since they don't fit the 97TT mounts.
Spoke to Raretoy who I bought my mounts from, said they are from the 97 TT. They appear the same as the mounts on my 97 NA.
Are the mounts and isolators on the 97 NA & TT the same?
I need some combination that works, and it would be nice to know if the 97 NA mounts & isolators are the same as the 97 TT.
Otherwise, I need a price on the isolators for the 97 TT mounts....
Mark
Super Moderator
93.5-96 NA AND TT = long motor mounts 6" long / short brackets
97-98 NA AND TT = short motor mounts 3" long / long brackets.
feeding your habit
Discussion Starter #12
1997 TT & NA motor mount brackets are the same... Isolators are interchangeable as well?
Price & PN's:
hose from Manifold to Valve cover: (Fiche 12261)
hoses from head to heater core: (Fiche 87209,87245,87246E)
clamps: 90467-2201
hoses/pipes: (fiche: 16282)
feeding your habit
Discussion Starter #13
Hey there Curt, what is the lead time on these parts, shipped to NH 03103?
PN's & prices please on the last few items.....
-M
Super Moderator
12261-46031 Hose, List 7.06 Cost 5.23
87209-14840 Hose List 24.81 Cost 18.34
87245-1b320 Hose, List 30.61 Cost 22.63
87245-1b330 Hose, List 37.81 Cost 27.96
90467-22011 Clamp List 4.25 Cost 3.15 Ea X 6
16282-46010 Hose, List 11.87 Cost 8.78
In Stock!
feeding your habit
Discussion Starter #15
TT and NA isolators (not mounts, got that squared away!) are the same PN in 1997?
-M
1 - 16 of 16 Posts
