1 - 7 of 7 Posts
where to install? please post pics....
mine has 5 wires....
red for +
black for GND
yellow for signal in
green for signal out
grey for.... well... doesent say...
please help!
Martin
Definately NOT 1J
Martin if your Auto, then you have the Wrong HKS SLD, the one you need is the t6, 12 wires.
If your a 6 speed then the Type 1 will be ok.
YELLOW - Speed sensor wire to ECU
GREEN - Speed sensor wire to loom
BLACK - Earth
RED - +12v
Gray or Bue (depends on SLD type) leave disconnected
Heres the ECU pinouts..
http://www.max-boost.co.uk/max-boost/resources/SUPRA_MKIV/ECU_terminals_fromMKIV_COM.pdf
RED - Splice into wire on pin 31 (Block e10)
BLACK - Splice into wire on pin 80 (block e9)
Cut Loom wire on pin 2 (block e10)
Connect YELLOW wire to end heading to ECU
Connect GREEN wire to end heading away from ECU
HTH
Definately NOT 1J
You'll find the ECU under the carpet at the back of the passenger footwell. a few 10mm bolts hold it in place.
The diagram shows what each pin on the ECU is for. When you unplug the loom from the ECU just match up which wires you want to tap into and the speed wire you want to cut using the diagram.
1 - 7 of 7 Posts
