1 - 4 of 4 Posts
i just did a JDM swap and i left off the egr system. i am having some problems. when i start the engine it lopes hard and klanks as it starts up. it also does this after i shut it down. also, its running rough. it has new plugs and wires on it. would the absense of the egr system do this?
It might run right......?
did u reconnect all the vacuum lines? when u remove the egr there are a few u need to re route to make it run right
did you install the required block off plates on the back of the head (exhaust port) and the intake manifold port?
check for codes.
the egr ports were already blocked off. it came in that way. it had a plug in the head port and the plenum port was just open with a bracket in front of it. i checked out the port in the plenum and it did go through but was blocked off at the Y pipe that connects the plenum to to the throttle body. as for the vacuum lines, yes, i capped the ones that i didnt reconnect
1 - 4 of 4 Posts
