1 - 9 of 9 Posts
The JDM swap went good just don't have a working tach. The NA was not compatible, will the TT Tach work with the JDM ECU? Thanks.
Your NA was a auto and your New engine is auto right?
Check you wires as it must have worked, I did once a swap with my friend, and it worked with no problems, but his car was a manual, don't know if there is a difference.
Anyone else know about the Tach issue. My mechanic was saying that the NA Tach needed like 12 amps/volts??? I don't know but what was coming out of the JDM ECU was only like 6. Does that make any sense to anyone. Thanks.
Maybe your friend was using the USDM ECU? The JDM ECU and USDM Versions are different. So I may need to get a lower voltage/amp (I really don't remember the terms he used) Tach to get it working. Any other ideas? Thanks.
Drew - I would first check to make sure it is plugged in. Sounds simple but we all forget sometimes. Being that you have a 97, I would think that it would work. I'm getting a TRD Tach soon in the mail and maybe we can meet up and see if that works. If not, find a stock TT for cheap in the forsale section......
Moved to the dark side
tt requires tt tach. NA requires NA tach. JDM or USDM doesn't matter.
I was waiting for you to respond. Where have you been? ;) Thanks Arnout, once again you seem to be the go to guy on these JDM Engines. Thank You.
!black
The signal source is the same for any flavor of the GTE motor :) So yes, TT tach will fix you right up, plug and play.
I'm assuming your talkin about the RPM tach. The NA and TT RPM tach is different. Just put in the TT one.
I'm ordering one as we speak. Thanks.
1 - 9 of 9 Posts
