1 - 2 of 2 Posts
What needs to be swapped from a USDM Transmission over to a JDM one to work?
I was told the oil pan and tail shaft, along with some sensors.
If anyone knows for sure what needs to be done any help would be appreciated.
The transmission is an auto.
Thanks for you help.
0 to gas station in 5 sec
I only had to swap the actual transmission mount. You don't have to swap the output shaft, but it makes life easier because there's alot more room for the speedometer cable on the passenger side. Other than that it hooks right up.
1 - 2 of 2 Posts
