1 - 13 of 13 Posts
I just finished my build on my TT, did a built motor, dual denso's, etc. The usual, Car fired up effortlessly but is having a couple issues.
1. The tach is not working, the speedo is a hair over 0 for some reason. AEM however does see RPM
2. I am seeing no vacuum, would there be any logical reason for this? A leak somewhere?
3. The car will idle but when I hit the gas it will hang up around 3k and sometimes act tough to rev off idle
4. After the ignition is turned off, the fuel pumps still run for some reason, they are wired to trigger off the 2 blue wires going to the fuel pump ecu twisted together.
I do have one unaccounted for connector on the engine harness, it comes out the same opening as the 2 connectors that go farther back to the trans. It's a grey 2 pin connector with brown wires going to it.
All help is greatly appreciated!!
Lee
no vac with gauge or on aem? Same system you had previously running the car? Tested for boost leaks? Come by shop before noon to see an awesome car before transport arrives
I did use the AEM prior to this build, v1.
Lee auto or 6spd? I am finishing a brand new wiring harness install tonight. If you send me a picture granted your Auto (?) I can help you find where the connector goes.
:lol: You never answered my question. You have a complete modification list?
AEM
s372r
Dual Denso's
titan 280s
just the typical supra stuff, I figured out the fuel pump issue today, now I just have to figure out the idle and hanging issues aswell as the tach
Mines 6spd, I'll take a pic anyway!
Discussion Starter · #12 ·
Neither of those, still can't figure it out lol...
1 - 13 of 13 Posts
